any thoughts on the old timing tuner box?
Does anyone have any experience with this box?
Curtis
Are you referring to this one from full throttle I haven’t heard of people having an issue with it.
If this is a 4th gen, get HP tuners, flash to a 2002 operating system, and use a relay and ground relay pins 30 and 85, and run relay pin 87 to pin R53 on the ECM, with pin 86 on the relay routing to the arm switch. (see relay #6 in diagram below)
I'm running a 150 shot so 6 degrees of timing is pulled.
