Direct Port setup for 250-300
Old Feb 27, 2018 | 10:58 AM
Tan327's Avatar
Default Direct Port setup for 250-300
Looking for recommendations on an ideal setup for the following:
Forged 12:1 LS3 416, th400 w/ 3600 stall, 4.10', 28x10.5 radial, 34-3500 lbs. The setup has been sprayed previously, unsure of the sprecifics though. Car will spend most of its time on a prepped track, but may see some 1/8th mile street and no-prep action so delivery is a major consideration.
Budget isn't set but would like to be around $3k (not sure if that's realistic). Any input is appreciated!
Old Feb 27, 2018 | 11:48 AM
qweedqwag's Avatar
Call Nitrous Outlet, they can set you up with a phone call.
Old Feb 28, 2018 | 11:35 AM
Z28SteveA4's Avatar
^^ I second that call up nitrous outlet. There setups are killer and just send your intake to them to bend everything up for you.
Old Mar 2, 2018 | 09:53 AM
ovaboost's Avatar
Nx or induction solutions had great luck with both they can also get you set up.
Old Mar 2, 2018 | 10:28 AM
Nitro Dave's Nitrous Outlet's Avatar
Please give us a all directly (254-848-4300) and we would can help you get a quote made for you and make sure to discuss your needs, and options that we can do when it comes to plumbing a direct port. What intake manifold are you wanting to do this direct port on?
