Disabling nitrous while two step is activated
A guru on wiring here may be able to give you a better idea, but I'd imagine there's a way to interrupt the arm signal from your switch that arms the system, maybe by grounding it out with a signal wire from your two-step when it activates? Then once the two-step turns off and you start moving the signal from the arm switch to the system circuit is completed? Not sure, slightly above my wiring know-how but I'd imagine there's a way.
