Nitrous on a M6
Old Jul 4, 2004 | 01:17 PM
White98Z's Avatar
Default Nitrous on a M6
I just installed a 6speed in my car use to have a Th350. How should i spray this thing. With the 6 speed i would launch on a 150 right out of the hole on a full throttle switch with a a window switch set at 3000 to 6500. I hear people saying they dont spray off line and others that say they do. Then people are saying start sprying after you shift to 2nd. So this would mean that you have a button that you are holding down? I would like to have it where i leave on a 75 shot and then when i get in to 2nd or mabe 3rd add the rest on to it? Any way to do this with out having to hold down a button. I can be doing that and trying to shift. Let me know your set ups.
Old Jul 4, 2004 | 01:50 PM
Black02SS's Avatar
If you run a progressive setup, then you could have it activate %50 right away and then in 3 sec progress to the 150. From what I have seen, the people that don't spray out of the hole are ones that have the stock rear ends. You can do what you want and still use a WOT switch. I don't like to try and push a button either.
Old Jul 4, 2004 | 02:09 PM
White98Z's Avatar
what progressive control are you talking about and where can i read up more on it. What is the diffrnce between this and the nx maxumizer
Old Jul 5, 2004 | 11:05 PM
BMN's Avatar
BMN
I got a window switch that u could hook up to your second stage. It won't let it come on untill you shift into second. Hit me up with a PM if your interested.
Old Jul 6, 2004 | 08:21 AM
neat's Avatar
I used a WOT switch inside my center console to activate my 2nd stage. I set it up so that the switch was pressed in while in first gear. That only allowed the first set of noids to activate (75 shot), when the switch was released it allowed both sets of noids to open for my whole shot. As long as you use a WOT switch on the throttle body, the 2nd stage won't engage until you hit the gas again after you shift.
