SBE LS1 nitrous setups
Changing to dedicated system for nitrous this season, 250-300 shot on 8 degress pulled with 9's for plugs and 112+ octane in dedicated system...that's the plan anyways...see where tuning takes me or the tow truck. one or the other lol
I've tried it every way, progressive, 2 stage, and single stage with mine. I was running an odd 2 stage set up when I tried it that way. 100 shot with a single nozzle before the throttle body that turned off at 4500 rpm then the 300 direct port would turn on at 4700. I'll spare you the details but I had a hard time getting the bugs ironed out with the unorthodox 2 stage set up. Running it progressive works the best but my Maximizer 4 has recently developed a mind of it's own so I'm running it as a single stage right now, gangster style with a bang button. I hit it at around 4200 rpms and get off when my shift light comes on.
I DO NOT recommend running it this way (big shot, no window switch, single stage, no progression) as this is a recipe for disaster if you don't have experience running spray this way.
Anyhow, B9EFS plugs gapped at .026 with C23 in a stand alone, 12 degrees total timing.
my 4an main line, and stalled auto only got 170whp with that shot tho. Just upgraded to 6an main feedline. If my wideband goes lean on the spray, then the 4an was a restriction.
