timing tuner...comments?
Originally Posted by SDB
If a professional place like APE couldn't do it, something is wrong. It is literally just two wires for the solenoids, and a plug-play harness for the crank trigger, and a ground wire. I did it and I am a complete **** when it comes to isntalling things.
Scott
OK guys but do I have the right idea here??? I know that running 93 octane and spraying could cause my timing to be to high and instead of getting my tuner to lower my timing and causing me to lose performance when Im not spraying I can get the timing tuner and it will take care of the timing when I spray! Please tell me this is correct because it souds like the perfect fix for me!!!!!!!!!!!
You know ,Its not AP's fault,Ram Chargers Directions just SUCK!I read it about 5 times and it just isnt clear on how this hooks up,If it wasnt for SDB I would have not been able to do it either.....
