1st time spraying at the track. Nitrous gurus input appreciated
Went to a 1/8 mile event. Weather was horrendous lol but felt the car did pretty good. Mid 90s and da of 27-3100
best motor pass was 7.16 at 94 1.48
cam and bolt on car 4l60e with 5c vert 4.10s .Suspension and 275/60 et street R .Br7ef plugs
50 hp jets in a NX maf kit tune was 12.7-12.8 afr. Pulled 3 degrees at peak torque then taper to 1 degree by 6400
went 6.87 at 97.5 1.41
75 jets same timing 12.3-12.5 afr
6.82 98.5 1.40
was impressed by the 50 jets but figd the 75 s would so better
6.82 98.5 1.40
what was your bottle pressure ? do you know the fuel pressure when using the NOS ?looks great ! make very little changes if you tweak any thing .your car is pretty fast with out NOS .
