NOS mini question???
Old Feb 4, 2019 | 10:32 PM
curtisad's Avatar
Default NOS mini question???
I recently installed a LNC2000 timing tuner in my 98 Z28, then I bought a NOS mini to have a progressive controller. If I'm reading right the NOS mini will not only progressively control the NO2 but will also be able to retard timing as well? Please tell me that I didn't waste money on the LNC2000?
Old Feb 5, 2019 | 07:22 AM
Hardtop Brian's Avatar
I don't have the NOS mini but I do have the lnc2000. I looked up the NOS mini and it looks like it doesn't retard timing, just has outputs for other devices. You would just connect an output to the lnc2000 to tell it to pull timing. This is how I have my window switch setup so timing is only pulled when the system is spraying.
Old Feb 5, 2019 | 09:01 AM
Jtm2085's Avatar
Correct, nos mini does not pull timing
Old Feb 5, 2019 | 01:24 PM
curtisad's Avatar
OK, I must have read it wrong. Thanks guys!!!
Old Feb 5, 2019 | 03:50 PM
brandon@nitrousoutlet's Avatar
Since the Mini sends a ground output, you will need to use it to trigger a relay that will send 12v+ to the LNC-2000
Old Feb 10, 2019 | 09:42 AM
5.7stroker's Avatar
This may help with wiring:
https://ls1tech.com/forums/nitrous-o...-see-here.html
