How Do I set the Window Switch on the Timing Tuner?
Old Jul 11, 2004 | 06:40 PM
Pro Mouse's Avatar
Question How Do I set the Window Switch on the Timing Tuner?
Ok I finally got my Timing tuner working,Now my Question is How do I set the Window Switch.I think I set the Max RPM (when it turns off)Right?You first set your RPM switch to what you want it to Turn Off,Then you set the base timing @ 8 ,Then you flip Switch 4 to on(UP)Position and then turn key on ,red light comes on for 10 seconds ,then both the Green and red light for 1 Second and it is done.Now what?How do I set it to make the Nitrous come on at 3000 rpms?
Thanks.....Scott
Old Jul 11, 2004 | 08:00 PM
B18B1LS1's Avatar
The RPM dial controls when the nitrous comes on. 3000 rpms is number 5 on your dial.
Jeffrey
Old Jul 11, 2004 | 08:21 PM
Pro Mouse's Avatar
Jeffery ,So after I set the n2o max rpm to turn off,I then go back and switch it to the rpm I want and That is where it will turn on? Do I do this when the key is on .....
Scott
Old Jul 12, 2004 | 04:22 PM
B18B1LS1's Avatar
You can change your settings whenever you want. The LED's are there to let you know it's hooked up right and all the functions are working. Your turn off rpm is the switch on the bottom of the box. I believe it's the number 4 switch, if you turn the switch to the off position your window switch is set to 5900, if you turn the switch to the on position your window switch is 6300. Or it might be vise versa on the rpms, check your instructions to make sure I'm right on that one! But that's how it works regardless. As far as turning the noids on, you should have a dial that reads "RPM", this allows you to adjust when the nitrous turns on, if you want 3000 rpms, that is setting number 5. Hope this helps!
Jeffrey
Old Jul 12, 2004 | 04:49 PM
LS1 BU's Avatar
What is the max rpm on the window switch. I've heard it was only 6300. I called Ramchargers and they claimed they changed it up to 7200. Can anyone confirm this. They claimed they changed it about a year ago.
Old Jul 12, 2004 | 05:02 PM
Pro Mouse's Avatar
Post
Jeffrey
I believe you are correct Jeff,I have to go back to the instructions to be sure ,but I think I read the Highest I can go is 6300 with dip switch #4 on.Thanks agin Jeffery..
Scott
Old Jul 12, 2004 | 05:04 PM
Pro Mouse's Avatar
I too am interested in knowing this...I will call RamChargers tomorrow and see what they tell me...
Scott
Old Jul 12, 2004 | 07:29 PM
Pro Mouse's Avatar
Hey LS1 BU did you still want that PI Vig 3200 Verter?
Old Jul 12, 2004 | 09:35 PM
algws6's Avatar
i just got mine put in and the upper rpm limit is 7400. this is a sweet piece.
Old Jul 12, 2004 | 10:59 PM
Pro Mouse's Avatar
Thumbs up
Yes after looking at the instructions that is what mine is too
