Stinger 3 vs annular fogger
Old Nov 19, 2019 | 07:43 PM
William.d.clarke's Avatar
Default Stinger 3 vs annular fogger
On the same pph say 1500pph . Which is going to be faster with the tune dialed in on both stinger 3 or a direct port Have heard that a fogger will out mph a plate.
currently have a stinger 2 so i know cylinder to cylinder is very good. Just a degree here and there with individual cylinder timing
Old Nov 20, 2019 | 08:45 AM
brandon@nitrousoutlet's Avatar
A direct port system is always the best option. The plates, do as good of a job as they can with cylinder to cylinder distribution. But, it's just not the same. Are you running Holley EFI?
Old Nov 20, 2019 | 01:20 PM
no I’m running a pro systems dominator and a mad 6014 What did y’all get out of the soft line fogger with the trash can noid. And how much does that kit run
Old Nov 20, 2019 | 03:59 PM
That setup flowed 626hp. Installed, that system would be around $1350. Since you have a system already, that's the price of the intake components, installed. Give us a call and we can get you a more accurate estimate on what you need.
