Pros vs Cons: Bigger pump vs Boost-a-pump
Old Apr 14, 2020 | 06:59 PM
ElkySS's Avatar
Default Pros vs Cons: Bigger pump vs Boost-a-pump
Currently running a racetronix 255lph and hotwire kit. With the combo I have planned, I could make as much as 800-850 on a 250 shot. Would a boost-a-pump be a good option or should I look at a dual pump setup and why?
Old Apr 14, 2020 | 07:20 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Keeping it as simple as possible is the best option.
But i assume you mean crank hp because 600rwhp na is pretty hard to do.
Our Hellcat drop in kit with Racetronix fuel line kit would be your best option. Your stock lines arent going to support the fuel flow needed there likely and its everything you need and can tap into the line easy for fuel.
I assume this is for an Fbody, seems like it is.
Old Apr 14, 2020 | 07:36 PM
ElkySS's Avatar
It is. I know 600rwhp is unlikely but I want a margin of safety
Old Apr 14, 2020 | 07:40 PM
ElkySS's Avatar
I also would like the ability to run E85 if I decide to do that later
Old Apr 17, 2020 | 02:51 PM
All of our pump kits are e85 compatible as well as all of Racetronix signature pumps.
Old Apr 19, 2020 | 09:01 PM
ElkySS's Avatar
It's actually for an LT1 car so I'm trying to figure out how to put a bigger pump in. Already had a racetronix hotwire kit and 255 pump
Old Apr 22, 2020 | 08:29 AM
Fishmasterdan's Avatar
If you really think you are gonna get to 850 RWHP on E85 you will need twice the pump. I ran an A1000 out at roughly 800 HP. Dry on E
Old Apr 22, 2020 | 10:03 PM
ElkySS's Avatar
Since I made this post, I changed my mind and decided to run a fuel cell for the nitrous so the in-tank pump really only needs to worry about on motor power, which probably won't go over 600 rwhp
