Rpm signal LNC2”
Is it possible to tap the LNC2000 coil harness for rpm signal output to be used with a window switch?
If not, could someone tell me which wire to tap on a 98 computer? I’ve tried two different positions that both the manufacturer and friends have stated worked and can’t seem to find rpm signal. All off the window switch settings are correct.
thanks!
thanks!
thanks!
thanks!
