LNC2000 Question
Old Nov 9, 2020 | 06:33 PM
nForceR's Avatar
Default LNC2000 Question
So im getting ready to wire the car up for nitrous. 02 Camaro A4. Im going to be using the LNC2000 and NOS Mini progressive. Im wanting to use the launch control function since it comes with the unit. If i wire the lnc 2000 launch wire to a wot switch on throttle body and to the brake light would this work so in order for the launch control to work it needs to see brake + WOT so its not turning on during the shut down after the pass. Also was just going to set the nitrous to activate 200 or so rpm higher so when i leave off the 2 step nitrous engages i know i could use 2 relays but car is already wired with a relay panel and don't feel like ripping it back apart. Thank You!
