New to LSx not Nitrous
Old Oct 30, 2020 | 07:56 AM
epfatboy's Avatar
Default New to LSx not Nitrous
Got a quick question.
Just picked up a L92 to replace a SBC in my '64 Nova. Will be doing a 230ish cam and will open up the rings a bit. Plan to use a plate and spray 250+ using a big shot wet setup.
I do I need bigger injectors, I was going to keep the OE's? I'm thinking no but thought I'd ask.
Old Oct 30, 2020 | 06:04 PM
Fishmasterdan's Avatar
If your current injectors work with that cam you dont need any more injector for a wet kit.
Old Oct 31, 2020 | 06:01 PM
epfatboy's Avatar
Thanks.
Old Nov 2, 2020 | 08:08 AM
epfatboy's Avatar
speaking of injectors..... How do I calculate what I need
I was thinking of going with some L96's which I believe are 44#, the stock L92's are 30#. Just not sure if that gets me where I need to be NA with a cammed L92.
Old Nov 2, 2020 | 09:13 AM
neblackshirts's Avatar
https://fuelinjectorclinic.com/hp-calculator
Can use this link to determine injector size needed.
Old Nov 5, 2020 | 11:18 AM
epfatboy's Avatar
Thanks for the link guess I should have searched first,
Good news, looks like some flex fuel truck injectors will work just fine!
If I'm reading this right some 44# L96 (Part # 12613412 8=$175) injectors will cover me to 650chp/550whp AND they are the same height as the current 30# L92's so I won't need spacers.
Old Nov 8, 2020 | 09:11 PM
qweedqwag's Avatar
Make sure you have a good fuel pump for your wet kit. I'm running a 265 lph on a 430 NA Ls1 with a 200 shot.
Old Nov 10, 2020 | 04:28 PM
epfatboy's Avatar
I have a Aeromotive Eliminator, it was feeding my carb regulator (aeromotive multi port with return) which in turn fed my fuel noid regulator, I hit this setup with a 300 shot. Now I need to find a fuel noid regulator that won't be overrun when I feed it from my EFI regulator. I was previously using a little holley regulator for the fuel noid but I'm not sure how it will react to 58psi hitting it. Actually I need a EFI Regulator too... #HemorrhagingCash
