Engine Temperature Rise with 150HP wet shot
I have a 1998 M6 LS1 Z28. My car has forged bottom end apart from the crankshaft, an aftermarket camshaft, which is installed by the car's previous owner and hence I do not know the specs, and stock heads.
I sprayed a 150 wet shot through a power ring kit and found out that the engine temperature increased rapidly from around 170 to 240-250 range during only one shot I sprayed from 2nd gear to 5th gear. Is this normal?? I had to wait like 5-10 minutes before the temperature decreased back to 170ish. Do you think I should decrease the shot or is this totally normal?
Tried a search and could not find anything related. Your help is appreciated, as I do not want to blow up the engine while spraying
Tnahx Trending Topics
