How much nitrous on stock 5.3
Hey guys new to ls ive got a mazda b2600 with a mostly stock 5.3 with a big ***** thumpr cam
Grind Number:291THR9
Engine Family:GM LS GEN III/IV 3-Bolt 8 Cylinder (1997-2015)
RPM Operating Range:2,600-6,800
Cam Type:Hydraulic Roller
Lifter Style:Hydraulic Roller
Camshaft Series:Thumpr
Camshaft Gear Attachment:3-Bolt
Usage:Street/Strip
Valve Springs Required:Yes
Camshaft Material:Billet Steel
California Proposition 65:WARNING: Cancer and Reproductive Harm P65Warnings.ca.gov
Advertised Intake Duration:291
Advertised Exhaust Duration:311
Intake Duration at .050 Inch Lift:235
Exhaust Duration at .050 Inch Lift:249
Intake Valve Lift:0.573
Exhaust Valve Lift:0.558
Lobe Separation:109
Assembly Lubricant Included:No
Intake Centerline:103
Lobe Lift Intake:0.338
Lobe Lift Exhaust:0.329
Vic jr intake and holley 750 carb how much juice can i run
Usage:Street/Strip
Lobe Separation:109
With stock type head gaskets and head bolts, I would think hard before going with more than a 150 shot. If you do everything right with the tune, timing and proper high octane race fuel, individual port injection, and didn't hit the button or had it apply progressively so it doesn't zap the engine at under 5000 rpm, maybe 250. All nitrous engines are running on borrowed time, not from wearing out but until you make a mistake. Make sure you have enough fuel pump. Even just bouncing the engine off the rev limiter can be a disaster with a big shot of nitrous behind it.
The following users liked this post:
G Atsma (05-04-2021)
Kawboom laid it out pretty well....
I sprayed a 250 shot on a stock 150k ls1 for 3 seasons almost every weekend. Everyone says 99 ls1 is supposed to be one of the weakest ls engine. Never hurt a piston or head gasket or anything. Never had a valve cover off. Afraid to left the magic out. Lol
