Anyone using a Cold Fusion Nitrous Kit?
WE WILL GLADLY HELP YOU OUT. Or you can call us and ask for mike 713-849-4120 I would like to add that for 2 solenoids to fail the same day is very unusual. i would like to have the old ones back for testing. You may have had things wired up wrong.
No offense implied in my post man, just thought it was funny.
On another note, I've been trying to find info on bottle heaters as there seems to be a difference in wattage in some brands vs. others. So far, I've seen people state that the NOS and your heaters are 300 watts and NX and a few others are 240. Is this true?
NX bottle heaters are 13.8 volt 240 WATTS.
NOS, Eldelbrock, Cold Fusion heaters are 12volt 300 watts
they all get really hot If wired up with a relay. Some times guys wire them up off of a toggle direct and use to small of a gauge wire to flow the current so the heater does not get as hot as it should. I suggest always using the relay as you probably know.
You also don't know me or my level of "EP".
all i was saying was that i disagreed with what you were saying about the ground. one thing that i do know is about basic electronics and how stuff like that works, thats it.
Mike, what is your view on this system?
Thanks!!
Douglas
