Anyone spraying >200 on a plate?
Old Jun 8, 2022 | 03:47 PM
98cherrySS's Avatar
Default Anyone spraying >200 on a plate?
I'm spraying 200 on a fast 92 Nitrous Outlet plate setup with a dedicated C16 fuel cell. It's great fun! I hear a 200 shot is the limit on a plate kit but I'm curious how far others have pushed.
Old Jun 18, 2022 | 02:08 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
I understand the reason for the question, because the only way I know of finding the limit involves instant motor blowup. I have heard people gripe about freezing a plate, but I have no firsthand knowledge. I wonder if stacking plates with something like a phenolic resin spacer could allow for more before that is an issue?
Old Jun 19, 2022 | 07:24 PM
ATwelveSec02Z28's Avatar
Change the intake to a single plane style, and spray it dry.....with a standard forward facing TB intake you'll be fighting distribution issues.
Old Jan 2, 2023 | 08:54 PM
qweedqwag's Avatar
Im spraying a 200 but my plate is 400 shot capable. Nitrous outlet plate Fast 90/90
Old May 20, 2023 | 10:11 AM
95maroz28's Avatar
The plate causes distribution issues issues with the stock ls1 intake or the single plane old carb style and elbow profile forward facing elbow for stock tb/aftermarket whichever size or adapter and tb is used? Just curious im interested in this as well. Does it the shark nozzle cause distribution issues as well thru bellow?
Old May 30, 2023 | 12:37 PM
SCJW's Avatar
The single plane intake should have better distribution, because of the location of the throttle body being centered on top of the intake. If running an elbow I would imagine you could use a 4150 carb nitrous plate between the intake and elbow.
Old Oct 9, 2024 | 03:33 PM
Bobby6speed's Avatar
ive sprayed a 250 shot through nitrous outlet 92 plate numerous times never had an issue. I did have a stand alone.
