What causes a nitrous backfire???
Old Aug 3, 2004 | 04:47 PM
Krazy98Z28's Avatar
I didnt think it was fuel, the dam thing was so lean it wasnt getting fuel
Old Aug 7, 2004 | 05:39 PM
94-98 Trans Am's Avatar
Who hooked the kit up, are you sure the fuel noid was working?
-Corey
Old Aug 7, 2004 | 06:00 PM
Steve@'s Avatar
Originally Posted by Fast94bird
Standard automatic, what gear was it in? How hot was the car? What was the bottle pressure 2nd pull.
Back fires are caused by lugging the motor, not fuel puddling.
I agree totaly, Ive had tons of backfires with dry kits and everyone of them was my fault, if I have had a window switch then I wouldnt have nailed it off the line at such a low RPM, Ive learned the hard way too obey the rules or you'll just break your car. Fortuanately dry backfires arent as bad as wet backfires. Remember that that explosion is going to follow the source of fuel and on a Mach1 its at the TB. Dave can tell you a few of my (STUPID) stories
Old Jan 13, 2009 | 08:59 PM
v3nuto98's Avatar
soo how can u prevent it from happpening? duz ur car run to lean or is it the nitrous kit that runs lean?????
Old Jan 14, 2009 | 04:46 AM
Krazy98Z28's Avatar
talk about bringing one back from the dead
Old Jan 14, 2009 | 05:08 PM
ShiznityZ28's Avatar
Originally Posted by buymeavette
its caused by a wet kit only. when fuel gets antomized with nitrous oxide sometimes the fuel falls out of the mixture. this happens because fuel is more dense then air mixed together.think of fuel holding onto air but falling out of place because its to heavy to move.
hopefully you understand this much. sometimes when to much fuel falls out it stays in the intake runners.this is called puddling, when to much finally is in there the fuel in the intake will ignite.... and well thats all she friggen wrote. if you have backfire ports in the intake normally this will prevent engine damage. LSX and NX make intakes for this purpose, so does hollys intake as well.
this is why most people run dry or dp kits. all kits can be made safe and with the proper tuning can last longer then engine life, but its known that dry leans out while wet "puddles" which is why dp kits are the best. you can adjust each cylinder this way so can run say 40 per cylinder. total that would be a 320 shot, not good on stock interals but you get the point. wet isn't exact neither is dry.... and neither is dp unless tuned properly.
but anyways i think i went beyond the call of duty, hope that answers your question. IMHO i wouldn't have switched a jet based on a 15:1 a/f mixture. maybe look at fuel pressure and play for fuel tuning first. answer nitro dave can probably tell you exactly what happened just give him full details and i sure he has heard it or done it himself.
thanks for reading,
erik
False.. dry kits can backfire also.
Old Jan 14, 2009 | 05:09 PM
You cna also back fire if you flote valves.
Old Jan 14, 2009 | 06:23 PM
Strahley's Avatar
Originally Posted by unit213
Larger fuel jet to richen it up and lower the A/F ratio.
Read that wrong, for some reason I read that as he up'd the nitrous jet not the fuel jet. Whoopsy
Old Jan 14, 2009 | 08:03 PM
Mike@HSW's Avatar
holy crap, 2004
I would say the backfire explination has been covered a few times since then
Old Feb 21, 2009 | 09:55 PM
LT1PwrdZ's Avatar
lol I just read this since i had my first backfire for the first time ever.. NX MAFF KIT
