High Pressure Nitrous Fuel System Questions
Ok, so I have a 1-gallon cell located up front, it goes through a filter then it goes to a Walbro 255lph pump (this is all with -8an lines), then it goes into the Aeromotive Regulator.. Thats where my questions come. How exactly should I have that plumbed? I know if your looking at the regulator from the front you have the fuel come into it on the left. Where should I put the return and where should I put the line for the nitrous. My guess, which I'm not 100% sure its correct is that the return is on the bottem (as usual) and the fuel goes to the solenoid from the port on the right. Am I correct on this??
