Nitrous question
Old Aug 9, 2004 | 11:04 PM
00BadassTA's Avatar
Default Nitrous question
I am new to the nitrous seen and I was just wondering a few questions about it. I was wanting to know what ideas to pick up extra to insure the safety of my engine. I have a 6-speed and I was wanting to know how to shift when I am using it, I am planning on getting a full throttle activation switch. I just need to know if I should power shift at all times or shift normal. Thanks for the help.
Old Aug 9, 2004 | 11:14 PM
Z28Venom's Avatar
This was is a list of everything that I bought to run nitrous on my M6 Z28..
Nitrous Express Wet Kit (used)
-NX-20920-10
NX Jets
-75
-100
-125
-150
Jimmy Jams WOT Switch ( You can't spray unless you're WOT to engage switch)
Gen X2 Upgrade
-Bottle Warmer ( Gives you maximum HP by providing best PSI for nitrous)
-FPSS ( disarms your nitrous system if fuel pressure gets too low)
-Blowdown Tube ( vents nitrous out of the cabin in case of too much press)
-Blowdown tube fitting ( required for blowdown tube)
-Bottle Guage (not necessary, but good to have)
-Purge Valve ( not necessary, but helps to give that immediate hit)
MSD Window Switch ( allows you to spray between preset rpms)
MSD Pills
-3000
-6000
NX Style Switch
NX Remote Bottle Opener
NGK TR6 Plugs ( YOU MUST RUN COLDER PLUGS)
I hope this helps...
Old Aug 10, 2004 | 03:40 PM
blubyeu2000's Avatar
a full bottle a couple jets {same hp shot} couple selonoids and a button. Then go tear peoples *** apart.
Suposedly if its a dry kit if you put the jets b4 the air sensor it will richin' up the fuel a bit. More than likely i am wrong thought so please dont quote me on it. unless im right then, you are very welcome.
Old Aug 10, 2004 | 03:49 PM
OnyxY2KSS's Avatar
i think if you powershift and do not have a window switch you will hit rev limiter, fuel will cut off, you will run lean and detonate
Old Aug 11, 2004 | 06:02 PM
00BadassTA's Avatar
so can I just shift normal and let the full throttle switch just do all of the work
Old Aug 12, 2004 | 01:41 AM
jd13's Avatar
m6 should really get a window switch unless you are perfect and never hit the rev limiter or miss a shift
Old Aug 12, 2004 | 03:39 PM
BMN's Avatar
BMN
Deff a window switch. It is a real cheap piece of insurance compared to a new motor.
Old Aug 12, 2004 | 07:18 PM
ZL1SS's Avatar
I highly recomend not power shifting on it unless you want to do some repairs. I learned this the hard way on my last car. Just get a window switch and a FPSS and you shall be good.
