How bad for the motor is it?
Every1 I've told thinks I'm retarded! It really makes no sense to spray a truck.... but hey, it doesn't make sense to lower one either.
Hopefull a wet kit will be easy to set up.
Thanks for all the help,
Derek
have you ever taking your truck to a track? to me spraying a v8 is spraying a v8. all these people saying "why spray a truck" will be pissed when you spray a 125 shot and w hiz on by them on the street
good luck man!Travis
On a wet kit, you have to watch the bottle pressure because you will always be adding the same amount of fuel, no matter what your pressure is. Same fuel is added at 1100 PSI, as is added at 600 PSI.
The only reason people blow their motors is because they were stupid and sprayed too much on a motor that wasn't modified to handle the extra power. Same thing will happen with SC'd and TC'd motors.
It depends on who you talk to about the limits of n2o on a stock motor. I spray 150 without a problem. Wet kits are considerably safer than dry kits, but slightly more difficult and costly to install. Don't forget the fuel pressure safety switch, it'll save your engine in the event of a malfunction and loss of fuel pressure.
My $0.02
Please tell me how you came to this conclusion, albeit the wrong conclusion.
Doesn't matter what kind of kit you have, it will disable the n2o if your fuel pressure drops below safe levels. Quite possibly the most important piece of the system.
Get a pressure guage and keep an eye on it. If you are not careful in Texas you will open the bottle in the summer and have over 1200psi, which would not be good. Low pressure is also not a good thing.
When I ran my 13.53 I only had 800 psi in the bottle. What do you think is the best pressure in the bottle? I have read hot rod magazine say 1100-1000 psi. What do you think ? What do you think I would run with that kind of bottle pressure. I think I was only spraying a 100 shot when I ran that time ,If that.
I have a buddy who blew up his motor on a dry shot.
Dry shots dont compensate for extra fuel like a wet shot does.
If you spray a 100 dry shot and the motor doesnt have enough fuel well its going to detonate there is nothing there to stop it. ON a wet kit ther eis extra fuel.
I'm sure Mr. Smits will have another flame for me on that one though. Edit: I should be more specific, the MAF does not add the extra fuel obviously, but it tells the computer to add more fuel to compensate for the extra air.
I think the dry guys and the wet guys are just going to have to agree to disagree.
My fuel solenoid failed to open with a 125 shot, It didnt cause any damage, I heard it pinging and I got out of the throttle.
These engines are more durable than I thought.
I have full bolt ons H/C, 11 to 1 comp ratio, on a stock tune and it still didnt grenade the motor.
Well my 2 cent's on this is i love nitrous it cheap reliable power.Yu should see peeps faces after i kick there asses launching with a 150 shot off the line in 4 hi in my 6000lb beast.
