How bad for the motor is it?
Old Aug 22, 2004 | 11:49 PM
  #41
Magic Chicken's Avatar
12 Second Truck Club
Originally Posted by Dustin 98TA
I just converted to a dry kit from a wet kit. I will probably go back wet eventually because it hits a little harder.
My fuel solenoid failed to open with a 125 shot, It didnt cause any damage, I heard it pinging and I got out of the throttle.
These engines are more durable than I thought.
I have full bolt ons H/C, 11 to 1 comp ratio, on a stock tune and it still didnt grenade the motor.
Good to know, thanks for that info.
Old Aug 23, 2004 | 01:50 AM
  #42
slik98z's Avatar
a dry kit will be as safe as the wet kit as long asyou take the right precautions. You can run a larger wet shot (which these also hit harder to begin with) than a dry kit out of the package...because it supplies its own fuel via solenoid. if youa re gonna run a larger shot just up the fuelp ump size and get a larger fuel noid...then the limit will be your bottom end of the motor.
If you want to spray more from a dry kit safely, there is another peice of the puzzle that you have to include along witht he larger fuel pump...injectors. the 28.8 lb injectors that come in some of our cars can handle a dry shot without using jets, which is reported around a 150 shot. i wouldn't recommend that on stock injectors, but on a set of 30 lb svo injectors or larger...i doubt there would be a problem.
another issue with upping the dry shot has to do with bottle pressure. the recommended bottle pressure is in the 800-950 range. colonel in his write up discusses keeping the bottle pressure upwards of 1000. doing it the right way is the part that is of most importance.
read up on colonels webpage. great information there about dry kits.
Old Aug 23, 2004 | 09:17 AM
  #43
Raben's Avatar
Do both if you have the money. Get a higher stall TQ along with the nitrous. Then due to traction reasons, spray once you hit 2nd gear and see your new times
I'm not going to go over the setups as it seems to be pretty well covered already.
Good luck and just be sure #1 you get all the safty parts and #2 have fun
Old Aug 23, 2004 | 10:00 AM
  #44
MilDot's Avatar
One other thing I did not see mentioned,
Dry is most commonly used for 75-100 HP gains.
Wet for 75-300 HP.
Direct Port for 300+.
The choice of system type should start with your plans for the car, not random opinions on which is safer.
Old Aug 24, 2004 | 01:13 PM
  #45
slik98z's Avatar
Wet for 75-300 HP.
very good point. If you are just starting out on a nitrous kit, i would personally go with a dry kit or a single nozzle or fogger wet kit and spray no more than a 125 shot. after a year or two after getting to know the system and most likely upgrading it along the way, thats when id start looking into the NXL kit or the MAF kits.
Old Aug 24, 2004 | 02:51 PM
  #46
1ScrudeDude's Avatar
I too am getting anxious for N20. 'Problem is, I got 4.10s, so in addition to a fuel pump and plugs, I gotta go with 3.73's and I JUST GOT my 4.10 12 bolt
Old Aug 24, 2004 | 02:54 PM
  #47
Why would you have to get 3.73's? My buddy has 4.10's no problems.
Old Aug 24, 2004 | 03:00 PM
  #48
Traction..? Oh, and running out of gear for the 1/4 mile. I have heads/cam, and am trapping 116-117 NA.
I can also get the delay, which allows N20 to come on after 2nd gear. I want to run 125 wet.
Old Aug 24, 2004 | 03:25 PM
  #49
Oh yeah, traction. My buddy is running ET Streets with his 4.10's and A4, he was also shooting a dual stage 400 wet shot and launching with the 1st stage.
Old Aug 24, 2004 | 03:40 PM
  #50
Jimmy Smits's Avatar
Umm... Yeah, what is your point? You gonna get out and change your jets when your pressure gets too high? That's what we were talking about, pay attention, especially when you're trying to flame people...
Please tell me your not really this dumb in real life? If you have your dry kit jetted for a 125 shot, guess how much you will be spraying, no matter how high the bottle pressure gets (before the blowout disk goes)? A 125 shot! What don't you understand about that?
Now when the bottle pressure gets lower, then you will be spraying a lesser shot.
Jesus man, you need to learn some ****...
Old Aug 24, 2004 | 03:42 PM
  #51
Whatever you say man, I'm done with your ignorant ***.
Edit: Actually I'm not. If you're jetted for a 100 HP shot (wet or dry) at 1000 PSI and you're bottle pressure goes to 1300 PSI you WILL be spraying MORE than a 100 HP shot regardless if it's wet or dry. Same if you have low bottle pressure, you WILL be spraying LESS than 100 HP regardless if it's wet or dry. Jets are pressure dependent, dumb ***.
Now I'm done with your ignorant ***.
Old Aug 24, 2004 | 04:20 PM
  #52
slik98z's Avatar
SHHHHHH.....Do you hear that fellas?
yes thats the sound of no one giving a ****
now...with this being a newbie to nitrous oxide...the original person who started the thread that is, whom we are attempting to help ahhh yes we remember now...Do we think fiddling with eachothers *** holes is going to help him with his decision?
yes jets are pressure dependent. Wet kits will make more power baring same variables. GENERALLY SPEAKING, if you spray a 125 shot wet, it will give you 125 rwhp. agan GENERALLY SPEAKING if you spray a 125 shot with your normal bottle warmer and **** its going to give you just aroudn 100 rwhp. there is a loss because of how the fuel and nitrous is supplied.
now are we done trying to figure out who is right and who is wrong? cause honestly it has nothing to do with this thread...
Old Aug 24, 2004 | 05:40 PM
  #53
It does have something to do with this thread. We don't want the N2O newbie getting the wrong information do we?
I would agree with slik on that. Good stuff.
Old Aug 24, 2004 | 10:05 PM
  #54
Holy Christ you are stupid!!!!!!! It doesn't matter if the pressure is 1300 or 1100, you WILL NOT spray more nitrous than the 125 jets allows through the hole. What don't you get about that???? They are jets for a reason. If you took the time to read the post you quoted, I stated that the lower the pressure goes, the less of a shot it will be, that is a given.
Please do not spread you automotive knowledge, or lack there of, to anyone else...
Old Aug 24, 2004 | 10:23 PM
  #55
I guess I need to get some of your Super Special Jimmy Smits High Pressure Regulator Jets. Jets restrict volume, not pressure. They can't regulate the pressure, therefore more pressure = more nitrous. I'll try to break it down into terms you might understand, although I don't think that is possible. It's kind of like putting your thumb (jet) over a water hose (n2o line), it restricts the volume of the hose, not the pressure. The higher you turn on the hose (pressure) the more it will spray. You're a dumb ***, I'm done with you. Good day.
Old Aug 24, 2004 | 10:47 PM
  #56
blkZ28spt's Avatar
Edit: I retract my statement as I am unsure now that I think about it. I do not KNOW so I took it down. I still think that what I put first is right......
Old Aug 24, 2004 | 11:48 PM
  #57
You can ONLY fit a certain amount of volume through a jet. That is why they restrict the flow. A 125 shot will only allow enough nitrous passed to be a 125 shot, not a 200 shot when the pressure goes up...otherwise everyone would blow the **** out of their motors.
If your thumb is covering the end of the hose, no matter what the pressure is, no volume is getting by your thumb, as your thumb is restricting the flow. Do you get it now?
Placing a certain size jet over the end of the hose will allow a maximum amount out of the hose at a given time. You can regulate this with the pressure, but when you reach the maximum, that is all that can get by at a given time, regardless of pressure (unless the hose blows into pieces). A 125 jet is the MAXIMUM that is allowed passed at a given time, regardless of how high the pressure is. When the pressure drops, then the maximum can no longer be achieve, therefore you get a smaller shot.
Old Aug 24, 2004 | 11:58 PM
  #58
You can ONLY fit a certain amount of volume through a jet. That is why they restrict the flow. A 125 shot will only allow enough nitrous past to be a 125 shot, not a 200 shot when the pressure goes up...otherwise everyone would blow the **** out of their motors.
If your thumb is covering the end of the hose, no matter what the pressure is, no volume is getting past your thumb, as your thumb is restricting the flow. Do you get it now?
Go squirt a water hose and come talk to me, let me know how it works.
Why do you think there is a recommended maximum pressure for nitrous and why do nitrous gauges have a red zone above 1100 PSI? It's not because that pressure is going to blow up the bottle, the burst disc doesn't blow until 3000 PSI or so. The red zone on a gauge is there to tell you not to use it because it will shoot more nitrous than intended and could have undesireable effects. High pressure isn't bad for the bottle (unless it's 3000+ PSI), it's bad for your engine. Take 2 full bottle to the dyno, heat one to 1000 PSI and the other to 1500 PSI and let us know how it goes.
But you have too much time invested in this conversation/flame war to back down now, so I know you never will no matter what proof I throw at you. Like I said before, I'm done with you, no matter what else you say, I will not respond anymore, it's useless, start a new thread about bottle pressure and it's effects on HP. Anyone care to pick up the torch where I'm leaving it off?
Old Aug 25, 2004 | 12:49 AM
  #59
QCKZ28's Avatar
let me offer some factual content about nitrous pressure and fuel pressure and how they affect jetting....
MAGIC CHICKEN is correct
JIMMY SMITS is wrong
bottle pressure/fuel pressure effects how much or how little n2o/fuel goes through your jets.
more pressure more n20/fuel
less pressure less n20/fuel
if your fuel pressure is too high you get too much fuel and go rich
if your fuel pressure is too low you dont get enough fuel and go lean (really BAD)
if your n2o pressure is too high (>1100psi) you get too much n2o and go lean
if your n20 pressure is too low (<800psi) you dont get enough n2o and go rich
jesse
Old Aug 25, 2004 | 02:34 AM
  #60
jesse
First off, we were talking about DRY kits, no matter how much n2o you spray, the maf compensates for it (to an extent), so you can stay out of this converstation since you don't know what the hell we are talking about.
Second, I never said pressure has no effect on how much n2o is allowed pass the jet, I already stated that it does; since obviously the lower the bottle pressure the lesser the shot.
My argument is - The jet only allows a MAXIMUM amount pass (being whatever the jet size is, ie a 125 jet will only allow enough nitrous pass to achieve 125 hp, no matter if the pressure is 1500 or 1000. Just because the bottle is at 1500 psi, that does not mean your 125 jet all the sudden turns into a 150 jet.
Occording to Tweety Bird, your 125 jetted shot turns into a 150 jetted shot if the bottle goes from 1100 psi to 1500 psi. And that is incorrect!
