N2o Solenoid leaks?
Old Aug 17, 2004 | 08:34 PM
Slart's Avatar
Default N2o Solenoid leaks?
Hey guys,
I just took my nitrous solenoid out of the box for some testing. I connected the hose to the "in", put the 1/8" pipe plug in the hole directly opposite it (which I assume is the purge).
The hole on the bottom is uncovered.
With the solenoid disconnected from the car, when I blow on the hose it leaks air from the inlet to the outlet (without being energized).
This seems wrong. Is this normal?
When I first took the solenoid out of the box the black lid (that says NX on it)
started to unscrew so, I put it baack the way it came and tightened the bolt on top by hand. It still leaked, so I tightened it lightly with a wrench.
Any clue what's up here?
Steve
Old Aug 18, 2004 | 07:56 AM
wholesalenitrousmike's Avatar
sounds defective. I would send it back to NX for replacement.
Old Aug 18, 2004 | 08:18 AM
Slart's Avatar
Thanks mike, I'll do that.
Steve
Old Aug 18, 2004 | 05:34 PM
ZL1SS's Avatar
Sometimes they will do that, before you send it back just kick it on with some juice and it should stop.
