Bypass question
Old Aug 18, 2004 | 12:31 PM
blubyeu2000's Avatar
Default Bypass question
i was told the reason my juice might not be engaging is becuase of the fuel pressure sensor thing on the rail. if so how do you bypass it.
Thanks;
stay pure.
Old Aug 18, 2004 | 12:53 PM
jamnut's Avatar
First off you don't want to bypass your Fuel Pressure Safety Switch, first try checking it. If you or someone else has an electric multimeter, turn on your key or even start your car and do a continuity test to the FPSS, put one probe on each side and if you set the meter right and you have enough fuel pressure the meter should ring. Telling you that you have a good connection. If it doesn't ring, then you either don't have proper fuel pressure so you need a new Pump/Regulator, or you have a bad FPSS so get a new FPSS. That thing isn't there to stop you from spraying, it's there to save your engine. I can tell you how to by pass it, but I won't.
If you are having trouble spraying, the first thing that I personally check is if the WOT switch is wired correctly. Some WOT switches have 2 prongs on the end of the switch & 1 prong on the bottom. If you have both of the wires on your WOT switch hooked up to the end terminals, it won't work, one wire goes underneath the switch on that prong and the other one goes to one of the prongs on the end of the switch, some times the prongs that you need to make your connections with are shaded red to help you know which ones to hook up.
Old Aug 18, 2004 | 12:59 PM
jamnut's Avatar
One more thing, double check all of your grounds. Specially the ones going to the relay that connects to your noids.
Old Aug 19, 2004 | 09:14 AM
it was the fpss. it would engage initially but then shut off. i bypassed it yesterday and when out and played till midnight( lost my liscence again starting in the morning)
The car is nuts
Old Aug 19, 2004 | 09:25 AM
jamnut's Avatar
The car is nuts
Get a new FPSS, that is a very stupid thing to do. You might not have a FPSS issue, you may have a fuel pressure issue, that's causing your FPSS to shut down your Nitrous.
I told you in my initial post not to bypass the FPSS, so now if you detonate and knock a hole in one or more of your pistons, I don't want to read about it on here.
Old Aug 19, 2004 | 09:47 AM
slow's Avatar
95%+ of the "fpss issues" are due to the fuel pressure dropping, due to the quasi return system/deadhead system of the ls1 f-cars
I have yet to see any "faulty" hobbs FPSS's, and i've sold/installed/tested many many of these units.
Ryan
Old Aug 19, 2004 | 09:52 AM
jamnut's Avatar
Ryan
That's what I'm talking about, if he sprays and it hits for a second or 2 then shuts off, that's telling me he is more than likely having a fuel pressure issue. So you are probably leaning out pretty good on the top end of your RPM spectrum, since you did what I told you not to and bypassed the FPSS.
Nitrous doesn't blow motors, Improperly used nitrous is what destroy's motors. **** like that is what gives nitrous a bad name in some circles.
Old Aug 19, 2004 | 12:56 PM
it sounded ok last night when i beat the hell out of it.
