question about when to spray
my question is this, do i push the button rightaway and spray trough all the gears, or do u just shoot like fron 2nd and 3rs, whatever u get up to down the track?
i need some tips on how to do this, thx guys
i dont kow if it amakes sense what im trying to ask
Do some research on the zex kit. Learn more about your nitrous kit before you go spraying that would be my only advice to be honest.
Get a window switch to set what RPM's you want to engage and disengage the nitrous. Typical setup is 3000rpms = fire nitrous, 6000RPMS = kill nitrous.
Also get a WOT (wide open throttle) switch. That way, even when you arm the nitrous, it will not spray until you go fully WOT. (and with the window switch, correct me guys if I am wrong, even armed and WOT, it won't spray until it reached 3000RPMS. So you'll be pretty safe.)
Think that's about it. Nitrous Dave can help with alot of other questions or items you need. Basically any nitrous dealer can get you the parts you need.
if you dont have a window switch, and you have a manual, i REALLY recommend getting one, one mis-shift can be fatal.
