Jet Question??
Old Aug 22, 2004 | 09:16 PM
02bluess's Avatar
Default Jet Question??
I'm in the process of installing an NX EFI kit for a Viper on my 02 SS, and I've got a question...
Although the Viper kit comes with two nozzles and the ability to run a 300 shot, I'm going to install it with one nozzle (similar to the NX GM EFI kit), and in talking with Nitro Dave, it sounds like I need 62 (N) / 33 (F) jets to run a 150 shot.
I've got a 62 jet, but I don't have any 33's. I do have a 35 jet, however.
My question is, what kind of difference (if any) would I see using the 35 (F) jets instead of the 33's?? Would it be noticeable?? I'm guessing if anything, it should be a little richer, correct??
This is my first time installing/running a nitrous setup, so I really have no feel for how much a difference this would make, so any insight would be greatly appreciated.
TIA!
Paul...
Old Aug 23, 2004 | 04:58 PM
02bluess's Avatar
Anyone?? All I'm really looking for is how much of an impact, if any, would running a 35 fuel jet cause in place of a 33??
Old Aug 23, 2004 | 05:18 PM
next's Avatar
Yes a 35 will make it run richer. A little rich shouldn't hurt anything, but the safe thing to do with nitrous is get a wideband dyno run to make sure where the a/f is.
Old Aug 23, 2004 | 08:52 PM
02bluess's Avatar
Thanks for the reply. I plan on tuning on a dyno w/wideband once I get it all together and the Racetronix installed. Just wasn't sure if I needed to go out and get the 33's before tuning, or if the 35's would be close enough.
Old Aug 23, 2004 | 08:55 PM
next's Avatar
Will be good to have the 33 on hand when you tune. Are you just throwing th 35 in to play with for now?
Old Aug 23, 2004 | 09:12 PM
02bluess's Avatar
I'd really like to be able to get it all tuned and good to go in one shot, so I guess I should probably pick up the 33, huh??
Once I finish everything up, the goal is to get to the dyno, make a couple NA pulls to check my a/f for my NA tune, then pull the tune down to an a/f of 11.5:1 timing at 24 degrees and let her rip.
I'm looking to run a 150 shot and hopefully hit some low 10's before the season's up
Old Aug 23, 2004 | 09:24 PM
next's Avatar
You're on the right track and I'd pick up a 33 and start with that.
Good luck.
Eric
