NXL Jetting
Old Aug 23, 2004 | 11:26 AM
Chrisrokc's Avatar
Default NXL Jetting
What size jets would I need to run 150 shot? Would this be ok on my stock bottom end? I would assume so because I ran 150 on a wet kit for along time. Wanna get over 120 traps.
Old Aug 23, 2004 | 01:57 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
There is not jetting for 150HP on a NXL System. 80,120,180,250HP
Ricky
Old Aug 23, 2004 | 04:08 PM
Chrisrokc's Avatar
Would I be safe running a 20 dry shot as a first stage and then spray 120 direct port? Is there any other ways go about getting more than 120 hp or so with the kit with out jumping to the 180?
Also is the 180 ok for a stock internal motor?
Old Aug 23, 2004 | 04:21 PM
NXRICKY's Avatar
The jetting is dictated by the orifice size and how many orifices there are. I can't make a pattern for the 150. I do not have an .011 jet. It jumps from 10 to 12. As far as the dry shot goes I am not up to speed on dry kit. But from what I have seen you should not have any problems.
Ricky
