5177 Noid
Old Sep 4, 2004 | 03:20 PM
2000Blackout's Avatar
Default 5177 Noid
Anyone running this dry kit with a bigger Noid? Thinking about switching to maybe a cheater noid.Anyone?
Old Sep 5, 2004 | 12:56 AM
Anyone?
Old Sep 5, 2004 | 01:34 AM
taqwache's Avatar
i had a home made dry shot with a pro shot noid and 6A line. it wont hurt to go bigger but the flow of the nitrous depends on the jet anyway. you should not see much of a gain unless you are spraying over 125 or so.
Old Sep 5, 2004 | 03:00 AM
Im not running a jet right now,thats the reason for wanting the bigger noid.
Old Sep 5, 2004 | 04:11 PM
PREDATOR-Z's Avatar
why??
5177 has 2 noids (powershots), they run in series and put out around 140rwhp with no jets. Tried and done it. But there is more to this system capabilities if some "out of box" thinking is used.
Run the main nitrous line into a T, out of which you run 2 single lines each to a single noid, that makes the ~ equivalent of 2 separate 5177's.
I ran that with #38 jets and ended up with 160 rwhp. Good way to make a dual stage too.
Koolrays ran a 250 dry shot this way and got his car nicely into the 10's (10.88)
Of course retarding 2-3* has to be done and a 10.8>11 A/F is recommended to take full advantage of this remarkably versatile kit.
I just quoted myself from another post
