September Nitrous Specials!!!
Old Sep 8, 2004 | 12:01 PM
Nitro Dave's Nitrous Outlet's Avatar
Default September Nitrous Specials!!!
Here are our september group specials.
Group 1
NX-20920-10,
Stage one single fogger nozzle system.
GenX-2,includes Automatic bottle heater,purge,fuel pressure safety switch,N20 Gauge, blow down tube and NHRA fitting.
MSD window switch with pills or BMN Window switch (your choice)
NGK TR6 Spark plugs.
COST:970.00
Group 2
NX-20109-10,Maff System
Your choice of heaters-NX automatic or 860 performance automatic heater.
Your choice of window switch MSD with pills or BMN controller
NX-purge
860 hex to wing adapter
Your choice of fuel pressure safety switch or nitrous filter.
Cost:1200.00
Group 3
TNT-F1 nitrous system.
Your choice of NX automatic or 860 automatic bottle heater.
Your choice of MSD window switch with pills or BMN controller.
NX purge
NGK TR6 spark plugs
860 performance hex to wing adapters for main feed line and blow down tube
Your choice of fuel pressue safety switch or nitrous filter
Cost:1166.00
Group 4
TNT F-4010-10 Direct port
NX purge
Your choice of NX automatic or 860 performance automatic bottle heater.
Your choice of MSD window switch and pills or BMN Controller
Your choice fuel pressure safety switch or nitrous filter
Cost 1450.00
Keep in mind that 860 performance is also having a rebate on there bottle heaters.
Call in your order at 1-866-648-7637
Thanks
Dave
Old Sep 9, 2004 | 06:49 PM
soslo's Avatar
Is the TNT F-4010-10 Direct port system tested and ready to go? or are there other issues to be concerned about?
Old Sep 10, 2004 | 09:25 AM
I guess I dont understand what you mean by this?
It is the system only you will have to plumb it onto your intake.
Dave
Old Sep 10, 2004 | 10:06 AM
soslo's Avatar
ahhh, ok. Thanks. I was trying to ask if it had similar problems to other DP kits out there (when they were released) without getting anyone worked up.
Old Sep 10, 2004 | 10:59 AM
No,The direct port kits from TNT and NX have been out for a long time with no problems.
Dave
Old Sep 11, 2004 | 11:54 AM
1QWIKZ's Avatar
how long is this special gonna last?
Old Sep 12, 2004 | 01:59 PM
Untill the end of september.
Old Sep 16, 2004 | 10:31 AM
To The Top..
Old Sep 20, 2004 | 09:12 AM
To The Top
Old Sep 20, 2004 | 05:12 PM
z06pdq's Avatar
a bump oughta be worth a t-shirt!
