Nitrous Cam?
Old Sep 12, 2004 | 11:56 AM
2002$$'s Avatar
yes i agree sportside, but i already compared all the cams ive been looking at within the companies...its just such a hard decision.i dont want over-the-top,but i want to make some real serious pwer.im stuck between a rock and a hard place.this is a lot harder decision than i thought it would be.
Old Sep 14, 2004 | 06:25 PM
2002$$'s Avatar
any other suggestions??
Old Sep 14, 2004 | 06:45 PM
Chuck@'s Avatar
I believe you'd be quite pleased with our "R" cam. It's a 234/244 on a 115 w/ .598/.612 lift. It'll run great on motor, and even better on gas.
Chuck
Old Sep 14, 2004 | 07:10 PM
2002$$'s Avatar
hey chuck, you spec'd me an "S" cam before...do you think the "R" will be alittle better under-the-curve?what are the rpm ranges on these 2 cams....thanks chuck.
Old Sep 14, 2004 | 07:21 PM
Chuck@'s Avatar
Both cams peak around 6300-6400. The S cam on our test vehicle gained power everywhere above 2500 rpm. Both cams have good area under the curve, but the R cam will be slightly better for larger shots of spray since it has the fairly large split.
Either one will be great for a 150 shot or less. 200+ I would go the R over the S.
Chuck
Old Sep 14, 2004 | 07:27 PM
2002$$'s Avatar
thanks chuck...i think ill go with the "S"...since ill be sticking with the 150-shot. how much is the package,again? ill probably get it at the end of the month.
Old Sep 14, 2004 | 07:30 PM
Chuck@'s Avatar
thanks chuck...i think ill go with the "R"...how much is the package,again? ill probably get it at the end of the month.
The cam package is 925 which includes the cam, springs, titanium retainers, and chromemoly pushrods.
Chuck
Old Sep 14, 2004 | 07:37 PM
2002$$'s Avatar
thanks chuck...ill be callin you on the 1st.
Old Sep 14, 2004 | 07:45 PM
Chuck@'s Avatar
Alright man, we'll talk to you then.
Chuck
Old Sep 15, 2004 | 10:40 AM
V6 Bird's Avatar
Chuck
This cam work good with stock cubes and stock heads? How much for just the cam? Ive got Isky295D's in the car already.
Mike
Old Sep 15, 2004 | 10:52 AM
Zach@Texas-Speed's Avatar
throw in a cam you think would best suit your driving style and performance preferences....if you dont like it, take it out and throw in a different one of your choice...after the initial tune, its only 50 bucks for a retune, and after you get the valvesprings swapped up, tossing in a different cam is nothing at all
Old Sep 15, 2004 | 12:54 PM
  #32
Chuck@'s Avatar
Mike
Stock cubes and stock heads should do pretty well. Probably will be somewhere around 390-410 rwhp. Our S cam on a stock 98 motor made 422 rwhp.
Chuck
Old Sep 15, 2004 | 04:54 PM
  #33
Sport Side's Avatar
Hey Chuck,
Is the "S" and "R", both nitrous ground camshafts, or are you just making a recommendation based on his setup?
Old Sep 15, 2004 | 05:46 PM
  #34
Chuck@'s Avatar
Originally Posted by SportSide 5.3
Hey Chuck,
The "R" cam is a nitrous cam. The "S" cam is an all motor cam, but could be used with nitrous since it is ground on a 115 lsa.
Chuck
Old Sep 15, 2004 | 06:27 PM
  #35
2002$$'s Avatar
chuck your tha man great service,dude!
Old Sep 15, 2004 | 08:04 PM
  #36
Chuck@'s Avatar
No problem... And here's a graph of the S cam on a stock headed 99 SS.
Old Sep 19, 2004 | 02:32 AM
  #37
2002$$'s Avatar
thanks again chuck,that "S" cam looks great!
