Who uses the DynoTune A/F switch?
Does any here use this? I was wondering how it works with stock O2s since the O2s operate in such a narrow range. What's the experience with everyone?
Is it true that when you check the timing with LS1 edit, it will not show the advance or the retard that you put in with the timing tuner? We changed the timing on dyno runs and it did not change in the LS1 edit reading.
12 Second Truck Club
