Popping (backfire?) after letting off...
Old Sep 12, 2004 | 04:17 PM
timbalan77's Avatar
Default Popping (backfire?) after letting off...
I sprayed a couple of times yesterday. Each time, after I let off in third to slow down, there were several loud popping sounds (I think they came from the exhaust, but not sure). This doesn't usually happen, so I was wondering what it might have been. My system is set to run pretty rich while spraying, so was this just a regular backfire? I'm not too concerned, because the car seems to be running fine - however, like I said, it's never done this before.
Any feedback would be appreciated. Thanks.
Old Sep 12, 2004 | 05:38 PM
ThackerSS's Avatar
exhaust leak is main cause
could be running rich also
Old Sep 12, 2004 | 05:47 PM
GM Muscle's Avatar
Mine does the same thing after every nitrous run. My car goes rich for a second as soon as I let off so I pretty sure it's from all the unburnt fuel getting lit up in the exhaust.
Old Sep 12, 2004 | 06:31 PM
MeanWS6's Avatar
you are running rich
Old Sep 12, 2004 | 06:42 PM
timbalan77's Avatar
Thanks, guys. Glad to know it's nothing to worry about.
Old Sep 12, 2004 | 08:39 PM
hellbents10's Avatar
LS1Tech Sponsor
I don't know if it will help but...after every run I shut down the juice while still at WOT and hold it at WOT for a second or two w/o the spray to clear things out a bit. I have never had so much as a hickup or backfire with running n20 for 4 years now, on a few different vehicles.
Old Sep 13, 2004 | 08:01 AM
koolrayz's Avatar
I had the saim thing only it can be a problem it blew my lid up. Only did it if i let all the way off all of a sudden. What i do know is let off slowly so the WOT switch closes but the nitrous in the intake clears. Itsa alot like helbents10 does.
Old Sep 13, 2004 | 09:50 AM
SDB's Avatar
SDB
Mine does it also, I will try to ht the switch off before letting off throttle, that should help.
SDB
Old Sep 13, 2004 | 09:42 PM
timbalan77's Avatar
Yeah, I was letting off all of a sudden. But, that's what I normally do, and it had never done this before. I'll try to get a couple runs in tonight and see if it still does it after I let off slowly. Thanks, guys.
