Have to cut lid for TNT power ring?
Old Sep 10, 2004 | 12:04 AM
soslo's Avatar
Default Have to cut lid for TNT power ring?
I was reading this instructions - is this a necessary step or is there another way to accomplish the goal?
Old Sep 10, 2004 | 12:36 AM
Turo's Avatar
yep, its probably the worst part of the install. i took about an inch off of my tsp lid, and cut a fernco bellows to fit just right.
Old Sep 10, 2004 | 12:38 AM
BIGBOS's Avatar
I wouldn't say thats the worst part, the worst is trying to get the ring over the TB, I had to file down the lip of the TB, and it wouldn't go on with it on the car, so I took it off and then hammered it on
I hear that some go on easier than others though
Old Sep 10, 2004 | 10:15 AM
soslo's Avatar
hrmm...that kinda sucks. Is there a comparable kit that doesn't require the lid to be cut? I think my clear MTI lid would shatter if I started horsin' around with it.
Old Sep 10, 2004 | 01:05 PM
Turo's Avatar
you just have to be careful when you cut it. i used a dremel tool and it worked out great, it made a nice clean cut.
Old Sep 10, 2004 | 01:07 PM
soslo's Avatar
ok, thanks
Old Sep 10, 2004 | 01:24 PM
jermstyle's Avatar
NX MAF Kit...
Old Sep 10, 2004 | 04:42 PM
LS1POWERHOUSE's Avatar
i just cut the bellow on mine. there wasnt much bellow left, but it sure saved my lid. it can be done. i have done it. but just be carefull.
Old Sep 11, 2004 | 09:19 AM
02SOMWS6's Avatar
I didn't cut anything.I have a SLP smooth bellows that I had to cut for my 80mmBBK ,I lubed the ring a little and it pushed in with no problem and my trimmed down bellows seems to be the right size.I have a SLP lid.My micro switch is giving me the problem here but I'm just gonna copy the design of the jimmy jam bracket.My problem is solved.Wish you luck with yours
Old Sep 11, 2004 | 09:24 AM
02SOMWS6's Avatar
lubed my up and it slid right into my 80mm BBK with no problem.Did you install it dry?I just put a little wd40 on my finger and spread it over the rubber seal and it slipped right in.I did try the hammer at first then stopped and calmed down a little, I was like a kid on x-mas
