Manual cars and Nitrous.
Dave
You need a TPS (Throttle Position Sensor) and a window switch. The only way the n20 will spray with this configuration is if you are at WOT (wide open throttle) within the window (RPM Range).
I have my window switch set to spray from 3000 to 6100 RPM. So any time I’m at WOT within this window I will be on n20. Unless you launch at WOT, you wouldn’t spray off the line so you wouldn’t have any trouble. Also, I read some place that there was a way to make it not spray in 1st, know anything about this Dave? That would defiantly solve the launching issue.
Dave
