Direct proportion between shot size and A/F points?
Also, how do most people set up fueling for nitrous? Do you have an alternate fuel program that can be switched to when spraying? I'll be tuning the car from the ECU EPROM so, it'll be complicated to have 2 different tunes that can easily be switched. Do some people just richen up fueling so that spraying is safe, and live with the richness othewise?
Any advice or discussion about your suggestions or your previous NO2 setups is much appreciated.
BTW: In my first post I said that with the wet kit your A/F ratio should usauly always be costant (in the 11s). I meant that it should always be in the 11s when your only spraying and not N/A. Take my set up for example, N/A my A/F ratio is a steady 12.8-12.9, on the bottle (175 shot) my A/F ratio is 11-11.5. Now with my old dry 125 shot to get that to run 12:1 on the spray I was having to run my N/A tune at about 12.2:1.
