NX Gemini MAF kit… Need a little help…
I opened up my NX MAF kit I received from Nitrous Outlet and laid all the part out to start the install following the instructions included with the kit.
Everything looked good and was going as planned until it was time to mount and plumb the solenoids. The fuel solenoid actually is the one in question as I cant see how it attaches to the fuel rail. I only have three lines, one feed line, one N20 line and one fuel line. In the picture of the kit from nitrousexpress.com there are four lines, all of the ones above plus a main fuel line that goes from the fuel rail to the fuel solenoid.
However, I did find a picture of a NX MAF install on the forum that had the fuel solenoid attached directly to the end of the fuel rail via some fittings (not included as I could tell).
So am I just missing a ton of parts? Or am I not following instructions?
Any help would be appreciated, thanks!
Jeremy
Jeremy
Your missing an AN-4 hose, it's not uncommon from NX, their quality control sux. Call whoever you bought the kit from and they should have NX send it directly to you.
Closed ex-Sponsor Account
Your missing a line. You should have 2 -4 lines and 2 -3 lines. Give us a call and we will send it out to you. We all make mistake from time to time. Please make sure that it is not in the bottom on the box. You are looking for a 18" -4 line with red bnuts.
Ricky
Ricky
Jeremy
Jeremy
