Which size
Old Sep 20, 2004 | 11:40 PM
dlandsvZ28's Avatar
Default Which size
Probably a dumb question, but need help. I want to order on-line a purge kit and a N20 filter.
I have a TNT F1 wet kit, but can't find anywhere in the instructions what the size of the fitting etc are and if I should order a 4n size or 6n size to attach the filter and the purge kit. One source says 6n is 1/4 inch.
Called three places today, but at all three got voice mail.
Thanks in advance.
Old Sep 21, 2004 | 12:08 AM
Z28Venom's Avatar
I believe the standard size is 4AN.
Old Sep 21, 2004 | 08:07 AM
WillieD's Avatar
the main N20 line and fuel line is 4AN. The lines that run from the noids to the jets are smaller, I guess those are 2AN lines....
Old Sep 21, 2004 | 08:39 AM
860 Performance's Avatar
If you use a 9/16" wrench its a 4-AN
If you use a 11/16" wrench its a 6-AN
The lines that go from the solenoids to the nozzles are 3-AN's
Hope that helps.
