How bad in nitrous on a T-56?
Old Sep 21, 2004 | 02:50 AM
SStolen's Avatar
Default How bad is nitrous on a T-56?
I've already blown one up on a stock motor and I thought I was pretty easy on it. I was just wondering how much damage I can look forward too with a 100 shot of TNT on top of a 400rwhp package? I WILL NOT be launching at the track; will most likely be an all-motor 4000 rpm launch and then spraying nitrous halfway out of first or beginning of second. I haven't tried it yet so I'm not sure. If you know, will I have enough time to react if I spray halfway into first? How much et/mph will I lose by not having a 12-bolt to spray off the line? Thanks- Mike.
Old Sep 21, 2004 | 11:52 AM
Devilss02's Avatar
You might want to get a stronger clutch it shouldn't be breaking stock. I saw that you have an s3. Get a window switch so it doesn't spray through the gears.
Old Sep 21, 2004 | 11:57 AM
Juiced's Avatar
not bad on the turbo, it will kill your motor
