Surging on a full bottle?
Old Sep 21, 2004 | 04:31 PM
5 Liter Eater's Avatar
Default Surging on a full bottle?
Got a fresh fill the other day. When I took it out for a 3rd and 4th gear run getting on the highway I noticed pretty pronounced surging. The bottle pressure was ~950 PSI prior to the run and ~900 after. My setup is the NOS dry setup converted to a wet setup using a Nitrous Works fuel noid at the rail and a NOS soft plume fogger right before the TB.
I wouldn't think 900 PSI would be low enough to surge. Could there be something wrong with my setup to cause this? This is not the first time I have felt the surging. I'm running 55/30 jets which may be too fat, would this cause surging? I didn't have my multimeter hooked up to be able to monitor the A/F ratio at that time so I can't say where it was at.
Old Sep 21, 2004 | 04:53 PM
nitrorocket's Avatar
Every setup is different, but generally the nitrous settings are set up really fat. I have always had best results with about 1150 psi with the recommended jetting.
Old Sep 22, 2004 | 06:09 AM
BTL FED's Avatar
Has it ever done this before? I would suspect a bad fill
Old Sep 22, 2004 | 07:31 AM
Yea, it has done this before. I can check the bottle weight I guess.
Old Sep 22, 2004 | 08:07 AM
koolrayz's Avatar
you may have a bunch of air in the bottle. I have seen where i had 7# left in my 15# bottle and it was all air. car acted similair to yours. I have a dry shot though so yours would be more pronounced. Do you have the NOS remote bottle opener? Mine caused surging also
Old Sep 22, 2004 | 08:09 AM
Z'mnypit's Avatar
Do you still have the FPSS? If so have you checked that? Mine used to surge bad when I had the FPSS hooked up. It would shut the system off & on during a run. It was really noticeable felt like the trans was slipping!
Old Sep 22, 2004 | 09:38 AM
These are all good ideas. I don't have the FPSS installed so it's not that. No remote opener either. I would hope I didn't get a fill full of air but only a weigh would tell. If you have 7# in the bottle it would have to be N2O though right? Never heard of 7# of air being in the bottle. I can see being mislead on bottle pressure and having it be air but not weight of the bottle.
Old Sep 22, 2004 | 10:56 AM
Nostang's Avatar
Your probably running too rich and that is why it is surging. Make sure you did not mix up the fuel and nitrous jets or it will surge too---I have done this before being hurried and the car surged like crazy. If that isn't the case, step down a couple jet sizes on the fuel and see if that fixes it.
Good Luck
Matt
Old Sep 22, 2004 | 12:19 PM
BTL FED's Avatar
Thats correct Air Doesnt weigh anything, if the bottle still weighs correct, crack the valve a little and make sure you are getting a good stream of nitrous
Old Sep 22, 2004 | 12:23 PM
Well the purge has a nice stream of nitrous so I think I am getting good flow at least up to the actual N2O noids. I'll weigh the bottle, double check the jets and if everything checks out I'll step down a jet or two and monitor what it does to the O2 voltage. If I get off my *** I'll also hook up my warmer and get the pressure up to ~1100 just to be sure.
Old Sep 27, 2004 | 04:38 PM
Well I rigged up my bottle warmer and @ 1100 PSI there is no surging. That solves that I guess.
My N/A O2 voltages are .93 and my nitrous O2's are very similar, like .91-.92. This seems pretty lean don't you think?
