Newbie Questions (used search)
Well got the 2001 z m6 54,000k in the shop getting most of the bolt ons right now along with fuel pump. Gonna have a 224/224 cam installed with a set of stage 2 5.7tea heads in a couple of months(still saving). However, i planned on goin with some nitrous as well. Very unfamiliar with the stuff. Not gonna ask how much is safe blah blah but im gonna be running a 100 dry shot to start and sticking their until i decide to get all forged. Im a bit confused on all the different swithes ans stuff. Gonna use the best dry kit available(tnt or nx). Was wondering the best/safest way to activate it would be. I like the push button but dont want to hit the rev limiter or let off gas and make a boom, and dont want to be driving a pass somone at wot and have the nitrous go off niether. My question is with keeping this in mind what is the best way to spray/activate the nitrous in a 6 speed. Dont want to acidently spray while shifting either. Can i have a swithc to activate the wot window so that the wot nitrous only comes on with a certain switch. ex. without switch is na all the time even at wot, then with switch activated na till wot then nitrous? Sorry for the long post, but i need to learn from the most knowledgable
I would deff. get your heads and cam done first and see how that power feels to you, i'm sure it will be a good little jump. But you will need a window switch for your nitrous system, as well as a WOT switch. As far as I know NX and TNT make wet kits not dry, and I would reccomend wet over dry.
Closed ex-Sponsor Account
Call Nitro Daves for the dry kit. As far as wiring goes a window switch is a must on any nitrous car. If you want a push button wire it in line through a full throttle switch. Then you have to be at full throttle, push a button, and be in window switches parameters before the system can work. The reason for the full throttle switch is ( YOU WILL ALWAYS LIFT YOUR FOOT, BUT YOU MIGHT FORGET TO MOVE YOUR THUMB OFF THE BOTTON).
Ricky
Ricky
12 Second Truck Club
the other alternative to a push button, is an activation switch which must be turned on before the nitrous will activate, same as a push button, you just don't have to hold the button. switch not turned on, no nitrous
which company makes the best dry kit for ls1s then? I swear NX and TNT made a dry shot kit. I jsut want a kit that will amke about as close to rwhp numbers as advertised(like nx or tnt)
