New best on 200 shakedown pass
Old Oct 7, 2004 | 05:51 AM
Nostang's Avatar
Default New best on 200 shakedown pass
I went to cecil last night to try out the 200 jets. Track was packed and there were a lot of spills/breakages so I only got 2 runs in 1 on the 200 and 1 NA for comparison. I was running 7 gallons of C10 in the tank and pulling 8 degrees of timing to be safe. My ET streets are pretty much shot (too much street driving..lol) so I took it very easy off the line especially after seeing fireball go up in smoke off the line with one of his 7000rpm dumps..lol. I eased off the line NA and then floored it to activate the fun gas. On the 150 jets it runs 10-1 A/F ratio so it is prob the same for the 200 using NX's recommended jetting. The car pulled like a **** and power was smooth all the way down. I knew I had a good pass when I was taching more than usual at the big end.
Timeslip:
1.592
4.294
6.595
106.73
8.588
10.277
133.24
compared to my previous 150 best of
1.437
4.199
6.565
103.79
8.615
10.354
129.14
Na run (setup for bottle):
1.711
4.865
7.511
92.84
9.810
11.760
115.83
My 60ft was about 2 tenths off and I figure with a new set of meats high 1.3's should be easy and I should be able to click off a 9 sec pass. I would also like to put timing at 6 degrees and see how the car responds. Time for a wideband. I want a single digit pass lol
Later
Matt
Old Oct 7, 2004 | 06:12 AM
VINCE's Avatar
Shorty Director
Wow!!! Thats a good jump.. Congrats..
Old Oct 7, 2004 | 08:07 AM
LS1 BU's Avatar
Nice gains. Can you give more info on setup??
Old Oct 7, 2004 | 08:14 AM
Nostang's Avatar
Setup is nothing fancy. GTP Stage 2 LT4 heads/intake, GTP-6 cam (235 242 112lsa), TH400 with a 9" nitrous verter~5200 stall on the spray, 3.70 gears, ET streets 28x12.5x15, eagle h-beam rods, forged pistons, stock polished crank, 2 bolt mains, and 200 NX single fogger kit.
Matt
Old Oct 7, 2004 | 08:18 AM
1a-play's Avatar
good job Matt, what size jets?
Old Oct 7, 2004 | 09:41 AM
Nostang's Avatar
78N and 62 fuel---10 psi setup
Old Oct 10, 2004 | 04:15 AM
Drew778's Avatar
Very nice
Old Oct 11, 2004 | 05:38 AM
Nostang's Avatar
Thanks for the compliments!
Matt
