fuel system question????
Old Oct 9, 2004 | 12:57 AM
DeepBlueZ's Avatar
Default fuel system question????
I'm almost finished with my 5177 dry kit and i plan to keep it conservative and only spray 100 (possibly 125 on occasion).
i know obviously there is plenty of fuel to handle the 100 shot on a stock motor but i also have a small 215/215 .573 lift cam that i'll be putting in in a couple months.
i was working out some numbers and came up with the following estimate. (keep in mind i was a little conservative on the hp gains from the nitrous seeing as its a dry kit.)
current rwhp = 341
cam only NA = 360-370
100 shot + cam = 440-450
125 shot + cam = 460-470
am i stretching the stock '98 fuel system with this much power??? injectors (i know i have 28s)???? pump???
Old Oct 9, 2004 | 04:22 PM
toxic99's Avatar
Racetronix PnP system is top notch and will handle your goals.
Old Oct 9, 2004 | 05:54 PM
DeepBlueZ's Avatar
so the stock stuff isn't gonna handle the spray once the cam is in there i take it????
Old Oct 10, 2004 | 02:52 PM
Robert56's Avatar
You'ed probably be at your limit, but maybe ok. I would get it tuned on dyno for sure though.
