Nitrous not firing
Ok guys, i haven't used my nitrous kit in quite awhile. When I decided to give it a try again the kit wouldn't fire, nor would my purge. I checked all the connections and they are in order. I'm thinking its the relay but i want to hear some suggestions on what it could be. I looked for relays and found some 40 amps at my local car parts place. I was wondering if i can use those or if it has to be a 30 amp. I have a Nx wet kit. Thanks.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
The purge noid is not wired through the relay.
If you dont hear the purge noid click when you hit it, you have a electrical problem with the entire nitrous system. If you DO hear it clicking, figure out why the nitrous isn't making it from the bottle to the n20 noid.
I started messing around with the kit again and i made the purge work. I hear the relay from the nitrous and fuel noid clicking, but not the noids themselves. I'm lost here.
