Need Help with Fuel Press Gauge Install
Well, I purchased the following kit:
http://www.speedshop.org/store/Scrip...p?idproduct=19
Now I need to know exactly what parts i will need to hook up to the fuel rail. Can anyone link to the proper parts on the summit racing site? Also, do you leave the schrader valve on or take it off.
As a sidenote, are there any good materials to both thermally and electrically protect the wires running up to the fuel rails?
Originally Posted by Brody
Thanks, will the gold fitting I have work, or will I need extra parts?
Also, how do you safely remove the valve?
unscrew it like you would on your tires looks like this and is on your drivers side fuel rail
13 Second Truck Club
Location: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
I bought the schrader valve removal tool at Pep Boys for $2. BlackY2KSS has it right, it's just like taking the thing off your bike tire or any tire for that matter.
*Edit* About the wires, all I did was zip tie and cover them with wire loom. They'll be fine.
