Rods, pistons, cam for nitrous use?
Edit: Would like to build this thing so it can handle up to 1000HP so it's ready in the event I get the turbo going.
Z28maro, i think you shouldnt state facts that you dont have basis on.
408 ci
Callies Crank
Grp Aluminum Rods (Have to be replaced every 120 passes)
Diamond Domed Nitrous pistons with Gas Parts (14.1 compression)
Hellfire Rings
Think about this. 4340 is 4340 no matter what. like 304 stainles is 304 no matter what. however some companies buy a crank and take extra time to polish them and knife edge them ect ect, but as for the stregth, 4340 is 4340.
Stock crank has proven to hold over 1k hp (Thanks Harlan)
As for pistions, i say Dimond is doing some of the best pistions for these cars, but hell fire rings should be used jmo 8.5 comp is a bad idea, id go atleast 10-1 or more, my car is around 12-1, no need to drop it like a forced ind car, n2o likes compresion.
as for rods, again all pretty much the same, but i run lunatie and i polished them myself (for oiling reasons) But Scat rods are probably one of the best, they take a rod and do all there **** to it, like beed blasting and polishing, real nice stuff.
cam with n20 for street driving, i say custom grind someplace around the 240 range and 600 range with a 110 or 112lsa. dont want to go to wide on lsa do to cylender pressure
Good luck with it, and with good parts and gas and the right tune up it shouls fly
Who are the select few companies that make the parts and distribute them to the other companies? After all, this is a place of knowledge sharing.
Scat had a 4340 crank break according to this guy http://www.thirdgen.org/techbb2/show...hreadid=256875 which would lead me to believe that not all 4340 is created equal, unless they were indeed advertising cheaper steel as 4340.
I want low compression because I plan to go turbo in the future and don't want to have to rebuild it again. Plus with gas prices they way they are right now (cheap Chevron is $2.45), I can deal with the loss in power due to low CR. However, race gas would be used on race days and tuning.
I'd love to use the aluminum rods, but this is a daily driver.
So back to the original question...
Rods, pistons, and cam?
Don't care about cranks. Thanks for all the input so far.
4340 is 4340, but that doesnt mean there isnt an imperfection in a piece or 2.
