HELP!!!! Stock injectors not good enough?!?!?!
Old Oct 26, 2004 | 02:07 PM
BriancWS6's Avatar
Default HELP!!!! Stock injectors not good enough?!?!?!
Well, ****!! I hooked up my NOS 5177 kit yesterday afternoon and checked with my tuner before filling the bottle and taking it for a ride. He said the stock injectors weren't up to par to use the kit!! I was like WTF, I have these plans to go to the track this weekend and hit bottom 11's and now this!! I had NO idea that my cars injectors with only a 225 cam wouldn't be able to support a 100-125 dry shot. Has anyone else ran into this problem? This sucks big time, anybody know a good place to get some SVO 36lb hr injectors, that's what he said I'd need.
Old Oct 26, 2004 | 03:28 PM
Z'mnypit's Avatar
I used to run the 05177 kit with a 125 shot in my car until recently when I swaped for the wet kit. I never had any problems with all the mods listed in my sig. I wouldnt be a bad idea to upgrade the fuel pump. But i never did. My fuel system is completely stock. Even the dyno #s in my sig are with the wet kit... You should be fine. Did you hook up the FPSS? if so then it SHOULD start cutting off the system once the fuel pressure starts to drop.
Vann
BTW: you may want to get some NGKTR6 plugs
Old Oct 26, 2004 | 06:39 PM
BriancWS6's Avatar
Anybody else? I know this kit is designed for stock injectors, the 225 cam isn't pushing the injectors that much harder is it? The stockers are 28lbs right. I need to figure out what to do, either tell the guy I'm gonna bring it up to the dyno and check the A/F ratio on the spray and hope he's wrong, or bite the bullet and get bigger injectors. I thought there were alot of guys running a cam and dry kit on the stock injectors. All help will be greatly appreciated. And thanks to 99PewterZ28 for your input.
Old Oct 27, 2004 | 11:35 AM
LS1M's Avatar
You can hook up an obd2 scanner to monitor injector duty cycle. That'll tell you what % the injectors are being driven. With my 2000 z28 (26.4# injectors), I run a 100-shot dry and get up to 85-87% duty cycle at 5900rpm, but I don't have many of the other power mods (cam, headers, intake, etc). Anything over 90% and your injectors are basically on all the time. I think your car's got 28# injectors (2001).
Old Oct 27, 2004 | 12:00 PM
383LQ4SS's Avatar
Id be willing to bet you are very close to maxing your injectors out. I would swap them for some 30s minimum...better yet some 36s. That will give you plenty of room. DO a fuel pump as well.
Old Oct 27, 2004 | 02:28 PM
BriancWS6's Avatar
I guess I'll look into some bigger injectors then. What brands are the best, Ford SVOs?
