Custom Nitrous Pistons Pics
Old Oct 27, 2004 | 07:55 AM
Magic Chicken's Avatar
12 Second Truck Club
Who made the intake? Any flow numbers on it?
Old Oct 27, 2004 | 07:57 AM
Noyzee's Avatar
8 second mod
looks like a nasty intake?
Old Oct 27, 2004 | 07:59 AM
Big Mike's Avatar
Btl Fed,
How bout giving up a little taste of what the motor setup is? Come on, throw us a crumb...
Old Oct 27, 2004 | 08:00 AM
Noyzee's Avatar
8 second mod
i think he said 408. i dont know for sure tho. no matter what it should be sweet.
Old Oct 27, 2004 | 08:32 AM
BTL FED's Avatar
Originally Posted by Big Mike
Btl Fed,
Its a Iron 408
Around 14 to 1 Compression
Solid Roller 275/290 732/731 114+4
I am Leaning Towards the ET Performance AFR Heads
Callies Crank
Grp Aluminum Rods
Kooks Stainless 1 7/8" stepped to 2" with a 3.5 Collector
Jesel Rockers
Comp 999 Valvesprings
Nasty Sheetmetal Intake w/ 2 stages of Nitrous
Accufab 105mm TB
Powerglide
NC Convertor
Moser 9" Narrowed 3" each Side
Mark williams Pro Stock Aluminum Bolt Through Center Section w/ 3.89 gears
Mark Williams 40 Spline Super Lightweight Axles
Afco Front and Rear Shocks
Mark Williams CF Driveshaft
Strange Brakes front and Rear
Madman Manual rack
Billingsley Manual Brake Booster
Big 3 Ecu
30x10x15 Goodyear Slicks
Wolfe Anti-roll Bar
BMR K-Member
Weldon 2345 Pump
3 Weldon Regulators
Nasty Gas Tank
Car should weight around 3000 Lbs with me, gas, cage, 2 full Nitrous bottles
I think Thats about it
Old Oct 27, 2004 | 08:38 AM
That is totally insane! Hope you get some videos when you run it! What kind of times are you hoping for with that beast?!
Old Oct 27, 2004 | 08:55 AM
LOnSLO's Avatar
Check your P/V clearance when you preassemble the motor. These huge cams require a little extra machine work.
Old Oct 27, 2004 | 09:02 AM
BTL FED's Avatar
I will definatly do that, I gave Chris at AP all the specs of the cam, and the heads when I ordered the pistons, they also made them will a little more clearance because I am running aluminum rods, and they strech at high RPMs, but I also check and double check and usually tripple check
Old Oct 27, 2004 | 09:04 AM
BTL FED's Avatar
I will be sure of that she still has a little while left before she hits the track I am hoping for 5-6 months, its hard to find time to work on her when I am working 72 hours per week My goal for the car is 8.70's but who knows
Old Oct 27, 2004 | 09:05 AM
LOnSLO's Avatar
Sounds like you have your bases covered. Keep us updated on the progress!!
BTL FED's Avatar
Originally Posted by Noyzee
my comp is around 11.5-12-1 i dont have quit the dome, but gas ports, larger rings, dimond $1,000 for the set ect ect. i had mine coated on the top tho.
love c-16 yes love the smeel ect hate the $8 price tag. hehe
That intake looks sweet!!!!! good luck with it man, im sure it will fly!
Mine will be coated as well, I coat all my own stuff
Old Oct 27, 2004 | 09:12 AM
  #32
Noyzee's Avatar
8 second mod
cool, what do you use? special sauce. hehe
Old Oct 27, 2004 | 09:20 AM
  #33
MADMAN's Avatar
LS1Tech Sponsor
I would dump the C-16 and look into the VP NOS fuel.
__________________
www.madmanandcoracing.com
225-343-9029
Old Oct 27, 2004 | 09:45 AM
  #34
Noyzee's Avatar
8 second mod
i run the sunoco 117 octain. it is an NOS supriem blend (thats what they call it)
i think it is a pretty good fuel, plus its what my local track sells
Old Oct 27, 2004 | 10:39 AM
  #35
BTL FED's Avatar
Thats what I do for a living, coat things, Coat with Plastic, Teflon, Powder Coat, and Engine Coatings
Old Oct 27, 2004 | 11:22 AM
  #36
MADMAN's Avatar
LS1Tech Sponsor
NOS is 120 octane.
__________________
225-343-9029
Old Oct 27, 2004 | 11:39 AM
  #37
Originally Posted by MADMAN
NOS is 120 octane.
The company is 120 octane? That's interesting!
Old Oct 27, 2004 | 01:42 PM
  #38
Noyzee's Avatar
8 second mod
cool, like thermal difusion and eitrium (sp) coating. i should send you some parts. coat my headers in pltnum!! hehe
Old Oct 27, 2004 | 01:54 PM
  #39
LASTLS1's Avatar
6 Second Club Moderator
Got my New Nitrous Pistons in today, man they look sweet. Thanks AP Eng
Here are the Specs
.043 / 1/16 / 3/16 ring stack
Hellfire Rings
H-13 tool steel pins
4.030 Bore
Gas Ported
Domed 13.5cc (about 14.4 to 1 compression with a 68cc head)
Wow! Very nice!!!
Old Oct 27, 2004 | 11:37 PM
  #40
CAT3's Avatar
Restricted User
FMR! Thats an INTAKE!
