Anyone spraying on a stock 10bolt?
If so how much are you hitting and when and what are your 60 fts
Thanks
Thanks
Stock Manifolds
Cats and Y
Loudmouth Exhaust
NX Wet kit and a 150 shot. cutting 1.7-1.8 60' (sprayin outta the hole)
There's also another A4 here sprayin I believe it's a 150-175 outta the hole...
here are the times.. Best n2o: 60ft 1.600 1/8 6.945 @ 100.21 1/4 10.838 @ 127.06 on ET streets
ET streets on stock rear..
Offaxis, yep, several off us in HI spray out the hole, myself and Andrew, Rex (35thSS) used to have a stocker sprayed out, Bode and ....... anyway. I hit the 200 a couple times, mostly 175 though, cutting 1.4s, Rex did as well. With the A4 its much more willing to handle it than the M6!
On mine, I had to replace the stock crush sleeve with a Ratech one, as it served its purpose and crushed, causing the rear input seal to leak. Other than that, no problems. Best 60' was using small 26x8.5x15" ET Drags.
99 formula 175 wet 1.9 60ft 11.84 @ 121
00 formula 200 wet 1.9 60ft 11.97 @ 118
both have stock torque converters and 3.23 gears. no spin. hit at 2k rpms. or close to it.
GM Muscle....sure it can handle for longer than many think, or I have a freak rearend, as well as Rex, Andrew and more. In the first 12 mo of racing my car, i made over 600 passes, with I would venture 1/3 on the bottle. And of those approx 200 passes, in one year, at least 150 were at or over 150shot. In HI we typically run a bottle ever Fri & Sat, and during events its typical to run a couple bottles *hard to count when theres normally 10+ f Bodies pitted together....* I chilled out the last 6 months before deploying, but still sprayed outta the hole, and when I get back, if I can find a new kit for good price I will do it some more.
Charlie
Charlie
except at the track..lol.Den
