New to Nitrous
Old Nov 4, 2004 | 07:31 PM
2000 SILVERADO's Avatar
Default New to Nitrous
Can anyone link me to or explain basically everthing about Nitrous? I don't know much about it but would like to. Thanks in advance.
Old Nov 4, 2004 | 07:39 PM
Chingon's Avatar
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Read the FAQ sticky at the top of the nitrous section.
Old Nov 5, 2004 | 07:40 PM
That helps but I'm not just new to nitrous, I'm new to cars and trucks. I don't know what most of the stuff it mentioned is.
Old Nov 5, 2004 | 08:00 PM
Chingon's Avatar
Well then ask a specific question and I'll try to help.
Old Nov 5, 2004 | 08:28 PM
Magic Chicken's Avatar
12 Second Truck Club
The key to learning about cars, trucks, engines, engine mods, nitrous, turbos, blowers, etc... is reading, reading, reading. This place has all the info you need, just not in one nice clean little post. The sticky notes at the top of most forums is a great place to start your quest. Good luck.
Old Nov 5, 2004 | 08:47 PM
Ok, what's stall first off, and also when you use nitrous, you push a botton to use it but will it stay on as long as you hold it down, or will it just shut off after a while? And what are long tubes and open headers(it's not nitrous but I want to know)? And I will try to read more if I find anything helpful, thanks.
Old Nov 5, 2004 | 11:14 PM
Z28Venom's Avatar
Not to be a dick, but you need to go to each of the forums that you have questions about and just read. The FAQs at the top of each will answer most of the questions that you just posted..
Nitrous... most, if not all of the nitrous users on the board use a window switch. You arm the system and thats it. You set the window switch for the circuit to be activated between certain rpms (3000-6000). For that set rpm range your car will spray the nitrous. Once your rpms drop below 3000 the car won't spray anymore.
Stall = Torque Converter (automatic transmission)
Longtubes... Exhaust Manifolds Pacesetter|Hooker|Kooks|Grotts
Open headers is just that.. Headers with nothing connected to them.. extremely loud..
